by shadowfax on Mon Dec 29, 2008 12:33 am
Dave,
I friggin' love you, man!
I got home tonight, heated up a citric acid solution, removed the bypass valve and adjustment assembly from the pump, and filled it up with the solution. Turned the spindle a few times, and filled it. I let it sit for awhile, emptied it out, and repeated that process 3-4 times. I cleaned up the rubber parts on the bypass valve and put some food grade lubrication on them to keep them soft, and reassembled it.
Reinstalled into the machine, routing the pump water out to the sink, and turned her on. Sure enough, after a minute the pump kicked in, and the pump part sounded fairly good. In spite of my 3/8" line, I think that my 0.5 micron carbon filter is going to have to go. It makes noise like it's getting sucked on when the pump kicks into gear, and the pump starts to make a funny noise after a bit that I think is cavitation. I fed it from a bottle, and this removed that noise, but the motor with a load sounds kind of... annoyingly loud. Maybe it was damaged from running with a seized pump.
Anyway, it works for now, and I don't need to replace the pump, which is excellent news. Anyone know if AC motors can be tuned/repaired, either by myself or a professional? For now I think I am going to live with it.
I haven't got to checking the steam knobs. I can't figure out how to get the lock nut off. I believe you turn it clockwise to loosen, but it really doesn't want to budge without some serious torque, and I am afraid of damaging the chrome...
The plot continues to thicken.
Nicholas Lundgaard
