I can sure appreciate your comments about how complicated espresso can be, but I love the complexity and challenge of it. I have been wonderfully surprised at how forgiving singles are on my Automatica compared to my experience with doubles on my Silvia.
Jim, any possibility of putting together some steps for people who really don't know some of the unspoken directions from your paragraph:
Order a Ceme from Jim as a replacement. You'll need two 11/16 or metric equivalent wrenches to replace the stat, and a jewellers screw driver to set it. The electrical connections go on COM and NC. The one I got was set to high, and you might want to give it a full turn before you install it. To set it, let the machine warm up with the bottom cover off, and the tank empty. If the pressure goes too high, unplug the machine, tip it on its side, set the pstat and repeat as necessary.
Here are the comments on the Ceme pstat page at 1st-Line http://www.1st-line.net/cgi-bin/category.cgi?item=09200014&type=store
* Replacement part for espresso machines that have a small pressurestat
* Two wire connections occur at the 9 and 12 position when unit is situated at 9, 12, and 3 o'clock
* Available in 110 volt only
* Superior to cheaper MATER pressurestats due to fact that these have a stainless steel diaphragm
* Not a returnable item
* Technical support and instructions not included
* Please note that current stock does not have deadband adjustment as shown with offcenter smaller screw - in addition, the deadband adjustment if turned too much would render the pressurestat defective.
* WARNING: If your current pressurestat has limescale buildup, a new pressurestat replacement will fail within the first 6 months and as little as 1 month. therefore, if you see limescale, it is best to descale your machine prior to installation of the new pressurestat as we will not cover the warranty or replacement if the new one fails for this reason.
* WARNING: It is possible that you can adjust the adjustment screw too much, and this will damage the new pressurestat. Therefore, you should only adjust the center screw at maximum of a half turn increment after checking pressure on machine's boiler pressure gauge. If there is an offcenter screw, this one is more prone to damage and we strongly recommend not touching it. We will not replace nor warranty the pressurestat due to adjustment damage by the customer.
Is it true that either electrical connection can go to COM and NC?
I have never tries this before and have some questions - and would be grateful for your answers...
Before installing: A full turn which way to lower the pressure?
After installing: "pressure goes too high... set the pstat" means turn it which way and how far?
The warning on 1st-Line quoted above about turning it more than half a turn contradicts your suggestion. Is this a problem?
Did you know it was set too high before you installed it or are you assuming Cemes are probably all set too high because you discovered yours to be too high?
"Tank empty" means boiler filled to normal levels and reservoir empty, right?
Thanks for your help.
Geoff
