by cbrew on Tue Jan 13, 2009 10:17 am
Can anyone help with my problem?. I have the semiautomatic which is about two months old. I decided to give the boiler a descale. I emptied the machine on its side through the steam wand, filled up with descaler, heated up and waited two hours. I then emptied the boiler, filled up with fresh water, then emptied again and turned the machine upright again to fill with RO water, this time the lights did not come on. I remove the yellow cover at the base and pressed the reset button, there was a click, the lights came on again and I filled up with RO water and started to heat the boiler. The boiler reached mid temperature and did not get any hotter. I let the machine go cold and turned on again, the lights came but the boiler did not even get warm. Can anyone help with my problem please. Also does anyone know if I can download a breakdown of the machine in case I need to work on it, thanks, ray.
