another_jim wrote:The underwater position of the pressurestat creates problems. The Maters the machines use don't work (at least for the current production run). I'm using a Ceme, which has held up for a year so far.
It is not a scale issue -- dropping the Ceme into citric just unfreezes the diaphragm.
I absolutely believe you're right - it really can't be a scaling issue. And when I do go through the descaling process, I really don't see any deposits on the pstat. As I mention, after the first Mater went south, the next two were Ceme's, but still had issues. Sounds like you've got a theory that it's the diaphragm inside the Ceme? You think that's freezing up?
After I go through the descaling process, I usually find about a day's worth of good behavior from it, and then more of the same issue. Do you suppose that the descaling process is somehow giving the diaphragm a slight boost as a temporary fix, but then suffering once again from the original problem?
When you say you drop the Ceme into citric...exactly what product are you talking about? And do you submerge the entire pstat into some solution? Can you elaborate?
Have you ever managed to take a Ceme apart? I've got one that's toast - no more life left in it. I'd love to disassemble it, and maybe snap a few pictures to see what part looks damaged, so I have some idea what I'm trying to fix when I use your process...
Thanks a lot, Jim. You've helped me with this a bunch in the past, too... Really appreciate the help!
