by erics on Sat Jan 20, 2007 10:17 am
Sounds like (no pun) a loose electrical connection at the three-way valve. There "should be" one dual wire connection at this valve with one lead going to the pump and the other going to the brew switch. With the machine UNPLUGGED, tug on this particular connection and check for "looseness".
While you're at it, might as well check them all, but I would go to this one first.
Eric S.
