There are a couple of threads here about issues with the Semi's boiler fill. My problem is similar to the ones described but a little different.
Here are the symptoms:
- The boiler manual fill works properly.
- Shots pull normally.
- For about 10 minutes after a shot is pulled, the water level in the sightglass very gradually increases about 1/4 inch.
- When I do a cooling flush, the HX seems to be empty, and it takes a little while for water to begin flowing. The water is not overheated as would be expected.
It seems like there are two possibilities:
1. A slow leak in the boiler fill valve that allows water to backflow from the HX into the boiler via the valve; or
2. A (dreaded) pinhole leak in the HX.
Before I start taking things apart or buying parts, is there a way to test which of these two possibilities is more likely?
I'm thinking it's the valve. If there were a leak in the HX, I think the pressure/temperature in the boiler and the HX would equalize over time, and a cooling flush would produce overheated water. Does this sound right?
Any advice would be appreciated.
