Elektra Semiautomatica 3 way valve problem - Page 2
Postby DrDregs on Tue Oct 18, 2011 12:38 am
Thank you Jim. The right advice as always.
Erics - What Stefanos illustration doesn't show is that the 3-way in the Semi is hard wired. It doesn't have a plug on the coil but two wires that exit the coil and go down the chrome tube into the base where they have crimped bayonet connectors that are too big to pull through the tube.
Thus you either have to cut the wires in the base and join them up again or cut them under the bell and put connectors on. Changing the solenoid is a piece of cake. The coil is a roast dinner - well, almost for somebody as ham fisted as me..
I don't know if a plug conversion will fit under the bell but I doubt it. Maybe someone has done it. :?:
"24 hours in a day, 24 beers in a case. Coincidence? I don't think so."
DrDregs
Postby allon on Tue Oct 18, 2011 7:04 am
If you get an identical replacement, you can use the existing good coil with the new working valve body and save the new coil as a spare.
...assuming the coil isn't the problem.
LMWDP #331
allon
Postby DrDregs on Tue Oct 18, 2011 7:21 am
I'll strip it down and descale in the next day or so. Learned opinion is a new 3-way will not be necessary. I have been a bit remiss lately because the water is soft to start with and goes through three filtration systems.
DrDregs
Postby stefano65 on Tue Oct 18, 2011 10:15 am
You might just be able to clean the pilot and might as well the gigluer without needing to actually replace it (the solenoid),
I see the valve getting stock often on semi-auto,
sometimes a little tap (after removing the fancy cover) with the back of a screwdriver gets the valve unstuck sometimes not
most likely your coil is fine but if not
the wires need to be feed in the pipe and the terminals crimp on.
Stefano Cremonesi
Stefano's Espresso Care
Repair & sales from Oregon.
stefano65
Previous
Return to Espresso Machines
