Dave,
Thanks for the advice. I have never descaled the Elektra. However, my water is between 0 and 50 ppm, so very soft. However, I tried soaking the steam wand to no avail, and with the steam wand removed, it appeared the steam flow directly from the valve was fairly anemic, which is to say, unless, I discover something new, I think I'm going to have to descale the machine.
I have a few questions, and apologize in advance for my ignorance:
cannonfodder wrote:Shut it down, let it cool. Turn off your water supply and unscrew the cap from the group. If it looks like the inside of a cave in there, you need to descale it, regardless of the steam issue.
When you say "unscrew the cap from the group," I'm not exactly sure what that is.
For the citric acid, what strength do you use, and where do you get this?
cannonfodder wrote:disconnect the water line to the pump and drop it in your bucket of descale
I assume you mean disconnect at the water source and drop that in the bucket so that the pump will take a suction on the citric acid? Also, I thought the rotary pump needed positive head at the inlet is this not true, will it take a suction from the bucket? Or do you put the acid bucket above the inlet of the pump?
Finally, is it safe to assume the acid will damage any chrome parts that it touches?
Thanks for your help!
Steve
