When you say "unscrew the cap from the group," I'm not exactly sure what that is.
Its the "bolt" at the top of the illustration below.
This would give you some indication of any scale buildup internal to the machine - not exactly 100% translatable in "grey" areas but if the group internals are pristine, its likely your machine is in good shape.
As an alternative, set your pstat to 1.0 bar max on a fully warmed up machine. Now open the steam valve 100% and discharge (submerged, obviously) into a pitcher of water. While doing this for a minute or so, what does your boiler pressure reading fall to? Post this result and other Elektra owners can compare.
Take some pics of your boiler top (and post same) and someone can advise what to remove to check your water level and the condition of your water level sensor. High water levels can diminish steaming power also.
