Electrical Circuit Diagram - Expobar Elegance 2 Group
Hi all
I am looking for electrical circuit diagram for 2 Group Expobar Elegance, an older model, Compact with 2400W heating element, 10 A, 230 V. Anyone able to help out? Please ask if further info required.
Cheers
Cheers
- erics
- Supporter ★
Disconnect the heating element(s) of the boiler and see if the machine will successfully come on.
edit- You could also try this source:
Crem International UK Ltd
Unit 3b Bently Wood Way
Network 65 Business Park
Burnley, Lancashire, BB11 5ST
Tel: 01282 458473 Fax: 01282 450355
www.cremtechnical.co.uk
Thank you, I will try this when I get a chance over the weekend. I have just now emailed Crem International.
I had previously checked the heating elements with a multimeter & found they had ~ 60 ohm resistance each. With the leads connected to the heating elements, there was connectivity between positive and negative elements, but taking the leads off the elements and testing for connectivity came up with: no connectivity between the leads, and no connectivity between pos & neg terminals of heating elements, which I find strange.
Thanks again @erics, the Crem International UK rep was able to provide electrical schematics for a bunch of newer models, with the Markus Mini Control 2 Group closely resembling my older Elegance (with some notable differences). Able to ID the problem & fix, all good now.
For anyone looking for similar info, can recommend emailing Crem International, or the following image was the particular diagram helpful for myself..
Items R.E.A., T.S.1P, P. and P.R.P. perhaps different, the topmost wire is not present in my Expobar, and both flowmeters grounded directly, not via Gicars.
Hope this helps someone
