ECM Botticelli ii pressure valve or blockage
Hi,
I have an ECM Botticelli II (6years) and it has just yesterday stopped flowing water out of the shower head/ but rather all flows back to tank as if too much pressure.
When I press the button to pull a shot water fills the boiler and after a few seconds will start to pour water out the pressure relief hose back to the tank. And only drips are coming out the head .
I forgot to turn it off sat night and was on the steam setting for 10 or so hours, so a prolonged high heat may be related.
Best I can guess is.
A. The pressure relief valve (brass thing ) is now stuffed but I checked that and it is (correctly blocked) ok buy I guess could be weak
B. There is a block in the boiler or group head.
The ECM bott. Has the boiler fitted right on top of the group head.
Just wondering if people have a suggestion before I go diving deeper. The pump appears fine.
Cheers .
Ramon
Cheers .
Ramon
Hi again,
Does anyone have any tips as to how I can fault find the problem at had.
So in short, the symptoms:
- next to no water comes out the group head (drips)
- all water is cycled back to the tank
I can't tell if it is the relief valve (how do I test), or a blockage in the boiler.
r.
r.
- HB
- Admin
Have you descaled lately? It doesn't take much scale to block a gicleur (a small orifice atop the grouphead in many espresso machines). I would start at the grouphead and work towards the pump looking for blockage.
Hi Ramon
I experience the same problem with my ECM Bott II ...
Did you find a solution to the problem?
Do you know of any repair manual for the machine?
I took of the top the other day ... But really like some kind of paper telling me where to start
Kind Regards,
Christian
Kind Regards,
Christian
