E61 - What tool to use to remove the big brass "screw" - Page 2
Link to "E61 - What tool to use to remove the big brass "screw""by Mark Well on Tue Feb 03, 2009 12:34 pm
JOB DONE!
I turned my machine upside down to unscrew it. I put some olive oil to help "lubricate", but I don't know if it helped...I asked the help of my lovely wife to hold on tight the machine while I was forcing with a 2$ CAD and a clamp. It worked!!! Now the water seems to distribute better in the showerscreen, as I avoid to tighten very strong...
thanks
Mark Well
Link to "E61 - What tool to use to remove the big brass "screw""by Randy G. on Tue Feb 03, 2009 5:06 pm
I used an American $0.25 piece. I put it in a vise, filed off the rolled edge so the sides were parallel, then changed the radius along one edge to match the screw's slot. I held it with a small pair of adjustable pliers, and it worked a charm. At the current rate, that makes it about a 12¢ tool. :oops:
Espresso! My Espresso!
Randy G.
Previous
Return to Espresso Machines
