E61 mushroom scale with Everpure Claris
- Viernes
- Viernes (original poster)
Nobody has a claris filter to compare? Should I set the filter at max setting?
- erics
- Supporter ★
This would be a good read: Everpure Claris - Adjustable Water Softening Filter System .
The most important action you can take is to test the water you are supplying the Claris and test the water coming out of the Claris.
