E61 double boiler machines with/without HX preheat
Link to "E61 double boiler machines with/without HX preheat"by EricL on Mon Mar 09, 2009 12:43 am
I have a question about DB performance when there is an HX preheat of the incoming water via the steam boiler, and that boiler can be switched off, as in the Alex Duetto. Has anyone compared the temperature stability with the steam boiler switched off and on? Seems like that would present some potential issues, maybe only in recovery time for the brew boiler since it's only a couple ounces of water in a .8 liter boiler.
[edit] - Just remembered the Bella Barista review, and it specifies that recovery time is the compromise.
EricL
Link to "E61 double boiler machines with/without HX preheat"by akallio on Mon Mar 09, 2009 3:38 am
I haven't played around with thermometer portafilter yet, but AFAIK the PID typically shows a drop of two degrees after pulling a shot. With group smoothing out temperature fluctuations there should be not much of a compromise in temperature stability. But if you are going to pull a lot of shots in a row, then it will start to make a difference. So according to me experience disabling preheat will slow down recovery, but will not make much of a difference when pulling a single shot.
akallio
Link to "E61 double boiler machines with/without HX preheat"by erics on Mon Mar 09, 2009 4:18 am
erics
Link to "E61 double boiler machines with/without HX preheat"by EricL on Mon Mar 09, 2009 11:24 am
Thanks, there was something rattling around the back of my head I couldn't put my finger on. I read that thread some months ago.
EricL
Return to Espresso Machines
