rickmonroe wrote:From watching the PID display, I see that the boiler temperature drops quite a bit as I pull a shot. To quantify, when I start the shot, the boiler temp is at 221 (for example), but by the end of the shot the boiler temp is at 213, or so. Is that normal?
There was only a 1 degree drop for the models we evaluated:
That said, the PID readout isn't meaningful once the extraction begins, though the thermocouple placement can make a significant difference in what it registers during the influx of cold water. In the kit designed by Jim Gallt (and sold by Chris Coffee), the SSR controlling the heating element is disabled when the pump is running. Unless there is an obvious taste defect or thermofilter reading showing a significant drop, I would attribute your readings to thermocouple placement, not actual temperature measured in the brewing chamber.
