by another_jim on Mon Jan 26, 2009 9:21 pm
The Petracco excerpt states that a taller puck requires a higher pump pressure. It would be easy enough to run La Spaz, DC and San Marco groups at 10 to 11 bar, if one feels the shots at 9 bar are underextracted or ground too coarsely.
However, this is hard to understand in context. He says taller percolation columns require higher pressure (and this is borne out in instant coffee plants), but he also states that the flow is maximal at 9 bar and actually slows down at higher pressures (and this has ben confirmed by people experimenting). The two statements together contradict each other, or imply that grind styles have to change if the puck depth changes a lot. Finally, most shots in Italy are singles, and single baskets have truncated cone cross sections, not a cylindrical one, and this either contradicts his statement about cylinders being optimal, or means that the Italians pull bad single shots.
The Illy book is wonderful; but it also has a lot of holes, non-sequiturs and contradictions, like this one, probably due to trade secrets.
Personally, I prefer the 58mm goups to the smaller ones I've tried; but I don't think the information in Illy invalidates the DC and LS machines. Also, my preference is based on very limited experience with small groups and a lot of experience with full sized ones; so even I consider it quite suspect.
