A big Thank You to everyone here for the excellent explanations.
JmanEspresso wrote:Once you have that figured out, you can alter it for "hot" "medium" or "cold" shot temps.
This is the one part that I am not following; once you have run the flush, wouldn't the temperature be stable as it continues to pull water through the heat exchanger? I was thinking of the heat exchanger like a instant hot water heater (only with the boiler acting as the heating element), where once it is on and running, it keeps giving you water at the same temperature.
I don't quite follow how you can alter it to "hot" "medium" or "cold", Does the heat exchanger act more like a mini-boiler where it has a capacity, then once emptied needs to re-heat?
JmanEspresso wrote:IF you desire precise knowledge of your brew temp, you wont get that with an HX.
I don't care if I know the precise brewing temperature, that really isn't important to me. I'm much more concerned about it being reasonably easy to operate and reasonably easy to produce fairly consistent results. When I have time, I don't mind playing with it, and adjusting things to improve my shot quality, but there are days where I just want it to work and make me a reasonable quality drink without a lot of hassle.
JmanEspresso wrote: However, what you WILL certainly get from an HX, is great espresso.
That is what I needed to know, that this will work well.
JmanEspresso wrote:Describing how to make espresso using an HX machine is the most complicated thing you could think of when it comes to brewing coffee. Actually USING an HX machine is far simpler.
From the things I read, and some of the videos I watch, they can make the process seem extremely complex; it's hard for me to know if they are adding some of these complexities out of necessity or if it is just them trying to tweak out the perfect shot. I'm starting to gather that it is more of the latter.
JmanEspresso wrote:(Granted you use a good grinder and high quality, fresh roasted coffee)
another_jim wrote:But while this answers your questions; it does not help you. Beginners tend to obsess about machine temperature, when they should obsess about their own skills instead. Skill in espresso means getting a few dozen things roughly right, not two or three things completely perfect. So once you have any sort of reasonable flush, 99% of your lousy shots will be due to ignoring all the other things to which you should be attending in the quest for perfect temperature control.
I have a Mazzer Mini E doserless for a grinder. I've used it to pull quite a few shots on the cheap-o espresso machine I have now. I think I've got a pretty good feeling for grind adjustment, tamping, dosing. With the machine I have now, it was pretty much a "guess n' pull" in regards to the temperature, with times the shots would turn out quite well and (many) other times now so well. I wanted to make sure this new machines gave me enough stability, that I wasn't going to have to play guessing games with the temperature.
I was at SCAA a couple of years ago, so I got to watch a lot of people making espresso and steaming milk correctly. I do hope once I have a good machine, I'll be able to start pulling (reasonably) good shots pretty quickly, assuming I understand the little "quirks" of the machine I get.
I've roasted with the Iroast with most of my beans from Sweet Marias. I also have a RK drum that I use on the grill. I'm thinking about getting a Behmor when I can; I'd really prefer to roast inside in the winter months, and the Iroast has seen better days.
Thank You;
Jamie
