More pictures on web site...
It is the successor to my first attempt at using an Atmel CPU for that purpose - the original but unreleased coffeeboard.
Currently, the project is in a "designed for geeks" state, ie. for those who have the ability to build and install such a thing and who want to write an OS for their espresso machine. At a later stage, I hope to to be able to offer a PID/brain box software package for it.
What it can do - with the correct kind of software:
* it can read ten (or more) different sensors simultaneously and let them affect the control loop - e.g. fresh water temperature, boiler temperature, brew presssure, flow rate etc. Such readings permit to add a feed-forward element to the control loop (equals faster response).
* it can drive five relays, solenoid or solid state, making it possible to control more components than just the heating elements as is done in a classic PID setup. For example, it could control pump, solenoid relay and the heating elements of multiple boilers.
* the module contains a zero crossing circuit for phase angle control; this could be used to vary the power supplied to a vibratory pump - and ultimately the brew pressure.
* for user feedback, the module can drive 14 LED (e.g. a bargraph), an LCD display and a piezo buffer. The backlight of the display is controlled by software.
* a battery-buffered clock chip could be used to warm-up the machine at programmed times.
* data can be sent to a connected computer via USB cable, permitting use of the module as measuring instrument to record multiple process values at the same time (record the presure-flowrate diagram of a pump etc).
* You probably have more ideas. Let me know.
