by boar_d_laze on Sun Sep 04, 2011 10:04 am
Hard to say what makes the difference.
Don't have too much confidence that pump and boiler gauges on two machines giving identical readings means the machines are both producing the same pressures.
What machines are we talking about? What are their respective conditions? Is one kept cleaner than the other? Different pfs? Shots pulled at different times during the day? Banging shot after shot out of one, and using the other one only now and then? Any other information you can give?
When you say "better," what do you mean?
It begs the point of your "why" question, but the first take-away is that given almost any imperfection, grind is the first thing to tweak. The second is that better machines make better coffee with greater consistency, and are more forgiving of small barista technique flaws (those may be the same thing). It's what makes them better, right?
Setting aside the obvious fact that your wife is unreasonable about the expense and sheer space needed to trade in your second-hand Rocky for an Aurelia two group, what about grind? Can you tweak it so the one group produces espresso as good (or nearly as good) as the two group?
Frequent fooling around with grind is a simple fact of good pulls. There are lots of reasons why, and some of them aren't well understood either. A big advantage of the professional barista has over the home persuasion is a willingness to keep tasting and sinking until the grind is right (for the day).
Uneducated Guess Time: Since we're talking about a two group (big machine) vs a one group (small machine), my first guess is a hazy stab in the direction of temp, temp stability and temp consistency. But it could be any of the things the other things already mentioned in this thread, it could be plenty of things not mentioned whether obvious or not obvious (head space for instance), and it could be a big fat combo.
Good question, by the way.
BDL
