www.veniacoffee.com: purveyors of specialty coffee and exceptional equipment
Differences in E61 shower screens
Postby pizzaman383 on Mon Nov 28, 2011 10:08 pm
I ordered a replacement E61 dispersion screen from an online vendor. When I installed it, it didn't seal unless I really cranked on the portafilter to tighten it. I thought I was doing something wrong. I happened to order another screen from a different vendor along with some other supplies. When I compared the three screens, here is what I saw:
The screen on the right came with my Vibiemme, the one in the middle (listed as a replacement shower screen for a Vibiemme) does not seal well, and the one on the left came from another vendor and works just fine. There doesn't seem to be a way to tell whether you are ordering a short or tall screen on most sites.
Has anyone seen this? How do you know whether you are ordering a short or a tall one? My Vibiemme seems to be sensitive to the screen height. Are other machines less picky?
Curtis
pizzaman383
Postby Randy G. on Mon Nov 28, 2011 11:33 pm
It would be nice to know where you got the short one and if you had made any effort to contact them concerning this and what their response was. Can I guess that the sort one was from a supplier which does not sell Vibiemme...? I thought all modern Vibiemme machines used the same group and so would use the same screen... Maybe not..?
Espresso! My Espresso!
Randy G.
Postby pizzaman383 on Sun Dec 04, 2011 1:00 pm
I bought the short screen from 1st-line where I bought my Vibiemme. I contacted 1st-line and they said that that was the only dispersion screen they stock. I sent them the pictures but have not heard back.
I received the tall screens that match the one that came with the Vibiemme from espressocare.
Not what I expected.
Curtis
pizzaman383
Postby cafeIKE on Sun Dec 04, 2011 1:41 pm
Sounds about right.
NEVER had a problem with anything from Espressocare...
cafeIKE
Postby chris on Sun Dec 04, 2011 8:53 pm
the short one also has a rivet in the center; the other two, if I am correct, do not.
Chris Nachtrieb
Pres. Chris' Coffee Service, Inc.
chris
Postby pizzaman383 on Sun Dec 04, 2011 10:05 pm
chris wrote:the short one also has a rivet in the center; the other two, if I am correct, do not.
You're correct. I've also got a tall one that's welded and has a center spot.
Curtis
pizzaman383
Return to Espresso Machines
