They are ABOUT $150 each - available from here: http://www.faemasource.com/ and allow you to adjust the machine for the length of the line out the door.
eric needham wrote:Paul,
Thanks! I wanted to ask you, but I always assume your too busy.
I used the scace and temp is 212 at idle and goes down too 200 after about 20 seconds which is a low as it gets. That is with the boiler set just over 1bar. I can wait to try the restrictors. are you running the boiler at 1 bar?
I am curious, do you use your speedster, lambro, or E-61 the most?
Eric
erics wrote:If not already equipped, a pair of these would be . . . nice.
<image>
I have just bought a 1968 single group machine and want to install restrictors
