www.zokacoffee.com: you're original, drink like it - single origin & artisan coffee
Descaling frequency based on water hardness
Postby coryforsenate on Fri Jan 27, 2012 3:19 am
I was curious for those that know their water's mineral content how often they descale. My total hardness out of the tap is 8ppm, which is very low.
Of course, there will be outliers from the people who make one espresso every other day and the people whose veins run brown.
And I figure the information here might be a useful thread for all espresso enthusiasts.
coryforsenate
Postby homeburrero on Sun Jan 29, 2012 2:52 am
There's an excellent but very detailed resource for this called Jim Schulman's Insanely Long Water FAQ
that you can use to calculate the scaling rate for a given hardness, alkalinity, machine use rate. It's currently available here:
http://www.big-rick.com/coffee/waterfaq.html
The above site may not be its permanent home. Check this Jim Schulman's Insanely Long Water FAQ topic for current info and location for that FAQ.
If that 8ppm total hardness is not a typo, you are off the chart, not sure you'll need to descale ever.
homeburrero
Postby coryforsenate on Sun Jan 29, 2012 7:07 pm
Thanks for the FAQ!
And it's not a typo, the hardness here really is 8ppm. Of course, we have really high alkalinity (~360ppm) and sodium (200ppm) levels, so cutting with some distilled water to reduce pH and sodium, and adding a dozen or two ppm's worth of CaCO3 helps out to balance the lack of any hardness (going off of http://www.scaa.org/PDF/ST%20-%20WATER%...V2009A.pdf). Calcium and magnesium are nearly nonexistent.
Off topic, it's completely useless for brewing beer. I get ultra-purified water from my lab and add the salts corresponding to the style of beer I'm brewing.
coryforsenate
Postby cannonfodder on Mon Jan 30, 2012 12:44 am
At only 8ppm, you may need to descale the machine in another 5 years, if that. That is very soft water. My water is 135ppm and I descale about once a year as PM but could go longer than that.
cannonfodder
Postby TimEggers on Tue Jan 31, 2012 1:46 pm
I also enjoy really soft water and haven't needed to descale in years (although I always check annually). I don't believe in rigid descale schedules, unless of coarse you know, based on your water, how often a descale is required.
TimEggers
Return to Espresso Machines
