erics wrote:No . . . although I do believe opinions will vary.
This espresso machine was designed to function well with a wide variety of coffee grinds, including those you might purchase preground, e.g. Illy, LaVazza (sp?) and others.
Should you really desire to experiment, a "standard" portafilter is available from this source: http://www.partsguru.com/SaecoPortafilters.html rather than modify your existing equipment.
Now, take some of this with a "baby grain of salt" - operating this machine with a standard portafilter will typically drive brew pressures into the neighborhood of ~13 bar in order to obtain the output you desire. This high pressure, in and by itself, has been shown to lessen the quality of the product.
Just curious, do you know who did these measurements and is there reference to it online somewhere? I understand the theory behind it but have seen some pretty good shots come from my modded Saeco Aroma while the pump is on the verge of stall for the majority of the pull. I'm assuming that puts me at lest at the 13 bar range if not higher by your earlier "grain of salt" statement. I'm trying to get my head around how the shots could taste so good and have such amazing body under these circumstances.
