Ok... I've followed the whole thing and have attached a version of your schematic that I've modified.
There are a few relevant differences.
My gicar is different. There are two banks of wires. Your power goes from the switch to the water level sensor to the common terminal of the pstat with a branch running to the gicar. Mine goes directly to 1l/1 with a branch to the gicar. My pstat common gets power from a wire on my gicar that is black. I will take a closeup photo of the gicar schematic tomorrow at work and post it.
My gicar has a second layer where ground attaches. It also has a sensor loop that goes through a water level sensor (bypassed) through the tank fill sensor and back (this loop is indicated on my diagram with the sensor bypassed - it actually goes to ground) There is another pair of wires that connects here that I haven't indicated - these go to the second water level sensor but they are jumpered because I have a direct fill kit.
You can see the direct fill solenoid indicated on the chart - it gets its power from the pump connections.
I have no power at my pstat common terminal. This indicates to me that the black cable coming from the gicar isn't supplying power. I've got to assume that this has something to do with either the waterlevel sensors or the boiler level sensor not being closed. But I've checked this repeatedly.
In the sensor wires there is
1 - a black wire which goes to the probe. This doesn't seem to matter if I ground, or remove completely
2 - a white wire which went to a water level sensor but now is jumpered to ground
3 - a pair of small wires (black/white) which went to a different water level sensor but they are jumpered together
I can't figger out what energizes the relay to supply power to the pstat. I've opened the gicar but can't trace it after it enters an IC. In the picture of the gicar below the first contact on the right (there are two mains in) isn't used.
Thanks,
mark
