hi,
i just installed a new sirai pressure stat, however, once the boiler heats up it starts leaking where the copper body attaches to to the upper steel housing where it is secured with the 4 screws. picture attached.
once the machine cools i will check the 4 screws.
also the temp gauge is stuck at around 1.5 bar, once the boiler heats up the gauge moves to maximum. is the gauge faulty? i will remove at descale the gauge for starters.
thanks in advance.
