Converting Nuova Simonelli Musica from Illy pods to ground coffee
I'm looking into a Nuova Simonelli Musica that's configured for illy pods. Does anyone know how to convert it from Illy iperEspresso Pods to accept grounds?
Thanks
Thanks
https://www.espressoparts.com/nuova-sim ... -plate-5mm
https://www.espressoparts.com/nuova-sim ... ead-screen
I can't recall whether you need a new screw or not.
It looks like the group head's description is stating that it's not compatible with models converted to pods
The screen isn't compatible with the pod dispersion plate. That's why you need the new dispersion plate too.
Great. Thank you. Somebody told me that it may cost $150 to convert from illypresso pods to ground!
- russel
Don't forget that you'll need a regular NS compatible PF and basket(s)...those will push the costs up to $100+. The new-ish NS PFs do feel really great in the hand.
russel at anacidicandbitterbeverage dot com
Thank you. I bought a bottomless one from the U.K.
Does someone know how do I remove the dispersion piece for the iperespresso pods so I can install the gasket and the regular dispersion plate and screen?
