tjkoko wrote:If I purchase a 220-230 volt espresso machine, would there be much difficulty converting it to 120 volts for use in the United States?
If you live in the US, and are planning to use the machine in the US,
why would you buy a 220v machine and then not run it on 220v???
I understand that many of the machines that are built to run on 110v were
originally designed to run on 220 and then "altered" for the lower voltage, often at diminished performance. So I can see why buying a 220v machine might have its advantages, but why buy one and then not take advantage of its power?
