by shadowfax on Fri Jan 23, 2009 1:45 pm
That's a pretty reasonable idea. You will likely want to get a 110V pump motor as well... those seem to run 300W or so, and the 220V ones might be even more. A transformer for this wattage will be a lot more than a simple transformer for low-draw electronics.
Reflecting a little bit, I don't think that you're going to have much luck with an LM conversion at all, even if you could change the elements. I don't think that a 2 group Linea is going to run well on 110V and 15A (or 20A for that matter). The 2 groups run a standard wattage of 3500W. That's about 30 amps at 110V, if I have done my math right. If you cut the element wattage down to ~2200W, I think you'd probably wind up with a pretty unpredictable espresso machine, not to even mention how long it will take to heat up.
Moreover, good luck finding a 2 group, and give up finding a 1 group. I've never seen one for sale second hand, ever. If you get it new, you can get it 110V.
Nicholas Lundgaard
