The reason for this is because my machine does not have any kind of restriction, the pick up tube in the boiler has a 1mm hole. If I was on the ball I should have done something about this before I assembled the group, now I would have to take it apart to braze over the hole and drill a smaller one. This is not an option as I would most probably wreck all the new group seals I put in a few days ago.
So I dug out a diffusor screw that I modified a few months back when I was messing about with pressure profiling. I was trying to smooth out the ramp up and down of the pressure of pre-infusion and post-infusion. Here is the dispersion screw that I used on my Linea machine. Stock screw on the right, modified on the left. All you do is tap an M4 thread into the screw and screw the stock LM gigleur into it.*
The screw is the last thing the water touches before the coffee. What I did was restrict the opening of the screw to 0.6mm. Works a treat.
So here is the older Marzocco diffusor screw (similar to an E61 screw) with the restriction.
With this in place my flow rate is down to 500ml in around 50 seconds and I have much more control over the pre and post infusion rates. By having the screw in this place the post-infusion rate is very much like a lever machine. Rather than a one-off pressure release you get a very gradual release.
What I have been doing on my manual (paddle machines) is when brewing as normal you back off the paddle and the pump disengages. You then get a lovely gradual decline in pressure and I love the coffee this way. On the solenoid machine I used with the Linea screw above, you still get a slow pressure decline.
The only drawback I could see with this is the potential for blockages with coffee. However I have been using a screw now for 2 months and not had any problems. Even if it did it is a 10 second fix as you just unscrew it and clean it.
The upside of this mod is that it is cheap and if you don't like it you just take it out in a few seconds.
As I said I like this as it has allowed me to control the flow on a machine where installing a restrictor in the usual place is not an option. Better coffee? well I like it this way.
Paul
* Actually I used a lathe for this and also turned down the gigleur head so it was more low profile.
