As Dave noted, you can still pull some very nice shots without installing a gicleur, but you need to be very attentive to dose, distribution, and headspace. Well... Even more so then if you had, say, a .6 gicleur installed.
What I would probably do in your situation, is order a .6 gicleur, and while waiting for it to arrive, I would go "back-to-basics" so to speak, on espresso prep. Mainly, using the
WDT method for your shots, and making sure of consistency with a scale. In my head, it would make more sense to try some lower doses, maybe between 14-16gr for doubles. What you describe(given fresh coffee) sounds like channeling all the way. Making sure you have enough headspace for puck expansion and using the WDT should help you out a bit. Then, when your gicleur arrives, install it. You might order 2 of them.
...WDT link hyperlinked from
http://www.home-barista.com/weiss-distribution-technique.html
