Cloudy water from Giotto hot water wand?
Postby VJHardcore on Wed Feb 03, 2010 3:20 pm
2004 Giotto Premium. I backflush a couple times a month and run citric acid through the water supply once every couple months.
I never use the steam wand except when the cleaning the machine yet often use the hot water wand for tea or my infant daughters cereal in the morning. I just recently noticed the water from here in a clean glass appears cloudy, not with bubbles but slightly hazy in appearance? It doesn't smell and I can't really taste any difference. But I don't think that's right?
Water from brew head seems to run clear.
Ideas?
Mike
"I'm a man of simple tastes, only the best will do." Winston Churchill
VJHardcore
Postby another_jim on Wed Feb 03, 2010 4:20 pm
Scale?
If you use the boiler a lot for hot water, you may be pumping through enough to exceed your descaling efforts.
You can let it cool, remove the vacuum breaker from the top, siphon it out and use a flashlight to see if the surface has furred up.
another_jim
Postby VJHardcore on Thu Feb 04, 2010 11:50 am
Furred...you mean scaled? So maybe I should just try a descale again? I'm handy but have yet to pull apart my machine - I'll have to look at a diagram to find the vaccuum breaker?
I never actually started to descale the machine (with Citric Acid) until a year or so ago. The machinces about 5 years old and I've always used softened water through it.
Any other thoughts or are we sure it might just be scale? Why is the water clear through the portafilter?
VJHardcore
Postby another_jim on Thu Feb 04, 2010 12:31 pm
The vacuum breaker is a valve at the top of the boiler. Screwing it out lets you insert a rubber hose and siphon out the water. This is a very convenient way of descaling, since it empties the boiler completely. It also allows you to look inside.
By furred, I mean soft scale, the sort that discolors water (like from old hot water pipes). Hard scale would leave your water clear. Scaling can happen at different rates in the boiler and the HX. It's good practice to fill your tank with distilled water once a week and flush the boiler by running the water tap. This will control the scale build up in areas where the water is only moderately hard.
another_jim
Postby davidmathews on Thu Feb 04, 2010 2:31 pm
Does the water clear after sitting for a while? I've noticed that i get a finely dissolved gas that eventually clears, it'd be my guess that's the case here. esp. because your HX machine keeps the water under pressure for long periods of time, your bound to get some gases driven into solution.
davidmathews
Postby VJHardcore on Thu Feb 04, 2010 8:55 pm
No I let the glass sit all day and its still slightly opayk (sp) like it was from the start. Its not like its cloudy per say. Its just ever so slightly hazy? I tasted it/smelled it. No smell and it doesnt taste harsh but alittle different then straight tap or the softened I run?
I'll try and get at opening it up this weekend.
VJHardcore
Return to Espresso Machines
