Peppersass wrote:Didn't you find the verdigris buildup during the period when you were using cation-softened water? Could it be that the copper tube is clean now because you switched to the Claris system?
That's not true, and the whole truth is way more complicated. I'd used
Cirqua AB Formulator packets for a few weeks, 'regular' salt-based cation softening, but mainly
Everpure Claris. Since then I've only used Claris. So it's possible that Claris is non-offending, but I actually can't rule out the possibility that the verdigris formation was from, say, leaving the machine with a drained boiler exposed to damp air for over a year. It occured to me that maybe what I saw on the top of the cap might also be from some tiny pocket of air that didn't bleed out when I bled the group last time.
Peppersass wrote:I think Ken postulated that the alkalinity in his cation-softened water may be responsible for the verdigris, though he said his level wasn't very high. Do you have alkalinity numbers for the cation-softened water you were using? My alkalinity level is around 150 ppm.
Is it your theory that the verdigris on the underside of the cap has caused the chrome to flake, or could it it have formed there after the chrome flaked off on it's own?
You can find my water test results published
here. The alkalinity I think was even lower than yours (100 ppm) for the salt-based ion exchange softener. My Claris numbers are very different, I believe at setting 3 (51 ppm hardness, 35 ppm alkalinity).
I really have no idea what makes chrome flake off brass when it's exposed to water, whether it's the scale/verdigris that separates the two, or some other process (and then the scale/verdigris forms on the newly exposed brass).
Peppersass wrote:FWIW, I wasn't using cationed-softend water when my gicleur clogged. I was using zero-water spiked with tap to produce 30-70 ppm (I was experimenting with levels.) My machine clogged after less than three weeks of use, and during that time I was using water with hardness and alakalinity around 30-50 ppm. If high alkalinity causes verdigris, I doubt it was forming in my first machine. My bet is that some of the chrome came off the underside of the cap on its own.
Here's another clue: As you may recall, at one point I found small metal flakes in the dispersion screw that were partially blocking the holes. When I tried to dig them out, they seemed fused to the inside of the screw, and I had to use a hand-held drill bit to scrape them out. It seemed odd to me that the metal could fuse at hot water temperatures, but maybe thin chrome flakes can adhere in some way to the screw material.
Well, it's too bad you didn't have a look in your boiler, or we'd know a bit more.
I imagine you're right about the flaking chrome (doing it on its own), but who knows. And if verdigris is mainly formed by air exposure from having an empty boiler left in a warehouse (or a tiny unbled air pocket under the cap), then you're just as likely a 'victim' (whatever that actually means) of it as Ken and me.
Paul, thanks for the historical data! It's interesting how many things they've played around with. I guess cosmetics wins on an exposed group, even though the cap is mostly hidden by the plastic group cover. Too bad we didn't luck out with SS like the Piero caps...
And that's sure the truth about the feed tube. I'd honestly hate to have to re-seal a SS compression fitting, so I can't complain that much. On the other hand, they could use a viton o-ring or something like that to seal the group side of the feed tube; they sure do on the back side (not sure if it's viton, but it is an o-ring).
Rats, Paul! You're
really tempting me. I am getting quickly attached to the idea of having the gicleur come out with the dispersion screw (great for backflushing as you say, and I already backflush without it). Time to order an M4 tap... I even have spare dispersion screws.
