another_jim wrote:The middle of nowhere is closer to an LM tech then Ken
And me, here in the boonies of West Central New Hampshire. Part of what we sacrifice to live in paradise.
The cost of insured shipping for a GS/3 would be on the order of $250 and requires truck freight. Chris Coffee ships them strapped to a pallet, which increases the weight beyond what UPS will take. Truck freight is always a pain for me because I have to arrange to meet the driver, and big rigs have trouble backing out of our 1/4-mile long driveway.
I guess the machine could be shipped without the pallet, but at greater risk of damage. Given the weight and large number of physical and electrical connections inside a GS/3, I think it's fairly susceptible to shipping damage or at least movement of critical parts. I believe that's the reason some GS/3s have been unacceptably noisy out of the box -- the pump shifts position during shipping so the input hose gets pressed against the brew boiler. I'm fairly certain my (replacement) GS/3's random reboots (now apparently gone) were due to loose connections in the control box that probably occured during shipping.
This is why I drove 300 miles round trip to Chris Coffee to pick up my first GS/3, and drove there again to drop off that machine and pick up a replacement.
When I first got into espresso, I didn't realize that I'd be rooting around inside the machines so much. But after only a few weeks of use, I was about to tear apart my Silvia to add one of Eric Svendson's thermocouple adapters to the group head. I avoided that surgery when I bought one of the bargain basement GS/3s, but then encountered a nagging flow rate problem, evidently caused by a clogged gicleur, that had me doing serious disassembly and testing inside the machine. When my replacement machine exhibited the random reboot problem, I took the control box apart, cleaned and reseated everything, and put it back together again.
Chris Coffee techs spent a lot of time on the phone talking me through the flow rate troubleshooting. They understand that the shipping cost and liklihood of further damage are not trivial, and are willing to help qualified owners repair their machines. For owners near a larger population area than me, they'll arrange for a local service company to come to your house. But that wasn't feasible for someone living in a rural area like me.
When my Baratza Vario's display started blanking while grinding, Baratza sent me a replacement display and I installed it myself. That was a lot easier than packing up the machine for shipping and being out of commission during repair. In fact, after I took the PCB out of the display I found the likely cause, a cold solder joint, and realized I probably could have fixed it myself without a replacement display.
Yet another story: I just received an EPNW custom 4-hole steam tip for my GS/3. The theads were incorrectly tapped, so it doesn't fit. Turns out the whole lot the received from the machinist is bad. They're sending a new tip when available, but meanwhile I re-tapped the threads myself.
Luckily, I'm a builder and a tinkerer, so none of this is foreign to me. I have many tools and lots of electronic testing gear on hand (heck, you need an assortment of metric spanners and other tools just to set the pump pressure and drain the boilers on the GS/3!) I generally don't hesitate to tear into a brand-new expensive piece of gear to attempt repairs, even if it's under warranty, to avoid shipping. I'm a little crazy, I guess, but aren't most people who are obsessed with espresso?
Yeah, it ticks me off that I've had to do so much to get my hardware working, especially given the high cost of the equipment, and I now see that the espresso equipment industry is too small to invest in proper QA processes. But I've found the same thing with high-end audio and amateur radio equipment.
I should add that none of the repair work I've had to do compares with the steep learning curve of making good espresso and microfoam. I'm doing pretty well now, but that's been a far greater source of frustration.
