shadowfax wrote:It's almost a 25% increase in flow rate; that's not trivial. I suspect you nailed it before when you guessed the effect of such changes is probably dependant on dosing style (I would add, overall shot prep style). I would guess that the heavier you dose and the coarser you grind, the more you'll see the water debit change your shots' overall flow characteristics. I sure noticed changes when I was playing musical gicleurs on my setup, though I'm hesitant to apply my experience here given my very different pump setup.
Hi Nicholas,
My view is that all of this stuff is more complicated than it seems. That 25% increase in flow rate is only present in a system with no resistance to flow. Once you put the coffee into the PF, everything changes! Preinfusion (the real type, not the programmable type on the GS/3 setup menu) is important when updosing, and much less so when using more moderate doses, in the range of 14g, as I use. There is something about the particle size distribution in a smallish, ~14g, dose that seems (to me) to be more adaptable to differences in pressure ramp up, than when using a larger dose ground appropriately for that dose, more nearly filling the portafilter.
We don't know enough about how Dave is dosing or grinding his coffee to go very far beyond this point in the analysis.
What I can say from my own experience is that (forgetting for the moment the "programmable Preinfusion on the GS/3") is that relatively minor changes in grind settings determine when I will see the first few drops of an extraction exiting the bottomless PFs in my machine. I doubt sincerely that the programmable PI in this machine changes very much. So to say that the first drops appear after XXX seconds now but it took xxxxx seconds before, well to me that is more or less meaningless. All it would take in my situation to get that sort of observable effect, would be to have a storm system pass through town, changing the ambient humidity, or having my coffee age a few more days. Titan level grinders are GREAT, but owning one or more of them does not mean that you won't EVER have to adjust the grind setting in response to changes in the environment or in the coffee itself!
ken
