cupojo wrote:I'm fairly sure the problem is not the coffee or the grinder. The grinder is a commercial grade Bregant burr grinder. The thing weighs about 40 lbs. I bought the beans recently from a local roaster after drinking espresso made from this blend at that roaster and it was excellent. I only grind for the day although I will save any extra for the following day.
OK, that sounds good. Just grind enough coffee for a drink or two at a time. Don't use grinds that have been sitting for a long time.
Could anyone confirm the hot water should shoot from all the holes in the disperion screen? I see water coming from maybe 20 holes. If that is normal I'm on the wrong track.
Water should come from all over the shower screen. It will sometimes form a cone into one single stream or several smaller streams, so you won't usually see it pour like a showerhead in your bathroom.
By the way I am making a single shot, filling the portafilter to the top before leveling with my finger and tamping hard to try for 30lbs finishing with a twist not under pressure. The amount of coffee used for the shot is around 15 grams. Using only 7-10 grams seems like very little coffee in the portafilter.
The shot size (single/double) is determined by the basket used and amount of coffee used (dose). Most singles basket struggle to hold more than 10g of coffee, so you may be using a doubles basket. The picture below shows the bottom of a singles basket. Notice that is has a small surface area where the basket is perforated.
Faema style single basket
For a blind filter, you can use a solid steel blind basket, or a rubber blind disk that sits in the regular basket. You might could make one out of a piece or inner tube, rubber mouse mat or similar material.
You should have a very capable set up there. I am sorry if I came off a bit harsh at first... I thought this was a machine serving customers. In any case, I'm glad to help.
Some helpful tips:
Get some espresso machine cleaner.
Clean or replace the shower screen and group gasket (spares of both are good to have).
Make a concentrated HOT solution of cleaner and soak the baskets (removed from the portafilter) and the portafilters themselves in the cleaning solution. Sometimes this is detrimental to the handles, so only soak the metal portion. If you get the showerscreen off in one piece soak it too. When you remove the basket, you'll have an idea if it is clean or dirty.
Backflush the machine a few times with cleaner and then just hot water.
The machine may need to be descaled, but you can check that out later if you like.
When using the machine, allow an hour warm up time before you try to make coffee.
If you are using a doubles basket, 15 grams is a great place to start. The doubles basket is generally easier to use than the singles basket.
The machines should be a heat exchanger machine, so read through the recommended reading (in particular the HX Love article) I mentioned before and you will be making great coffee in a very short time.
Post some pictures (or a video) if you are so inclined (here's how -
pics,
video).... and ask any questions you'd like.
