Looking for a one or 2 hole tip. Ideas?
Thanks!
HB wrote:If you look closely at the picture below, you'll notice I substituted Junior's stock four-hole steam wand with the one that is standard for the La Spaziale S1. This three-hole steam wand is slightly shorter and has sharper bends, thereby allowing more freedom of movement. Unlike the standard Cimbali wand, it can directly reach all the way to the back of the drip tray (the stock wand extends lower and can only go beyond the forward edge if rotated; on the other hand, the S1 arm doesn't quite reach the driptray, so plan to purge wand condensation into a pitcher rather than shooting for the driptray--or risk being sprayed). In addition to the added mobility, I think the smaller holes increase the velocity and make for better small-volume steaming.
