I have buy a used Cimbali M32 Dosatron,..
I have some problem here, hope i could find help from you guys..
1. Start-up problem
When I switch the power on, from usually we will hear an instant beep and then the display shows up..
But now, the is no more instant beep.. a blank screen, and sometimes i must wait 2 minute before the beep and the display shows, sometimes 10 minute.. sometime 1 minute only... any advise why this happen ?
2. Pump power source problem
We know, when there is not enough water on boiler, there is an automatic system to refill the boiler rite ?..
Okay,.. when not enough water in the boiler,... the low water indicator light go on (OK), filling solenoid valve open (OK), Pump Dead (PROBLEM).
First i guess, the motor capacitor maybe bad, but after i test the motor, it all okay, it run well and could pump water well..
The motor get power from a wire N(Blue) and Phase(Brown), and a Ground(Yellow). When I by pass the Phase to main source, the pump is run. So, there is no problem for the Neutral wire/source.
Then, i trace where the black wire come from...
Here it is the black wire source : i put an arrow..
and here its the complete main board area :
Any idea how to fix it ?...
3. Small capacitor blown up
After the main switch (Off-ON-HeaterON) , i found 3 small capacitor,.. two of them are blown up.... but, after i remove those two,.. the machine still work.. any idea what is the use of those small capacitor ?
All the rest function is okay...programming, etc. all okay...
Thank you very much before for your help.
Regards,
Jhonny
