I recently picked up a Cimbali M30 Bistro. It was just too good a deal to pass up. The problem is I can't plug it in! It is a 110v 20 amp machine and I have only 15 amp circuits in my kitchen. Rewiring is not an option because I'm renting.
So... after doing a bit of online research it occurred to me - the Cimbali Junior DT/1 is a 110v 15 amp machine. The two machines *appear* to have the same boiler (2.25l) and the same element mount. Does anyone know if they are in fact identical? Can I simply pull my element out and stick in one meant for a Junior DT/1 thus making this a perfectly functioning 110v 15 amp machine?
Here are a few pics of my new beast. Hope they help:
It seems very clean, inside and out - no signs of leaks or burns anywhere!
Here's the boiler. I've read threads about other Bistros, their boilers seem to share the model number 495007 but the last two digits are not always the same. I've seen 91 and 92 - mine is 93... leading me to believe that's the date of manufacture.
Now with heating element cover off. I forgot to get a good pic of the model number, but it is 321032, 115v/20amp [EDIT - it's also stamped 1800w. By my math that's 3 coils @ 600w each], and is stamped 10/92. You'll notice in this photo something that I thought very curious - there are 6 spade connectors sticking out of the element but there are only 4 wires connecting to them. As you'll see in in the photos below, this element has 3 heating coils. If 3 coils are 600w each, does this mean that someone has wired this machine to run 2 coils at 1200 watts (and a low enough amperage draw to run on a 15 amp line!?!?)
Element removed. Some scale... not too much. Soaking in Dezcal as I write this. You can clearly see that there are 3 individual coils. And... one tube (in front). What does the tube do? Half of the element gasket is attached to the element...
The other half is still stuck to the boiler. An even closer inspection revealed that there were two gaskets, one stacked on top of the other. I measured the opening where the element sits - the Inner diameter is 50mm and the outer diameter is 58mm:
Another shot of the ruined gasket. I'm already starting to make a shopping list of goodies needed to bring this machine back to her former glory:
While still scratching my head about how to solve me heating element problem I decided to get to work on the more mundane cleaning and maintenance tasks. Nearly everything in the machine looked very clean except this! All I can say is NEVER let you grouphead look like this - YUCK!:
And GROSS! I've since completely disassembled this end of the machine and these bits are spotless... but, man, I can't imagine what the espresso was like out of this thing! Who let's their gear get like that?:
So... If any of you have tried this element swap or have any other suggestions about the best way to make this machine run on 15 amp circuitry I would be glad to hear what you have to say. Any thoughts on the photo of the element showing the 6 spade connectors but only 4 wires? Does it seem to you that it is ALREADY wired to run on 15 amps using only 1200 watts of the 1800 available? Maybe the solution is staring me in the face.
Thanks in advance!
Alex.
