Hello Jimdk:
Jimdk wrote:I understand that the Jr. can't suck from an external tank because of the dosing chamber ...?
From what I can tell your D/1 is like mine: plumb-in, vibe-pump and autofill.
If this is so, you will need a minimum level of water pressure (the manual says something about it) not only to fill the doser tank but most importantly the boiler, which means that the differential between water mains pressure and the boiler pressure has to be enough to actually fill the tank when the autofill sensor opens up the corresponding valve.
I do not use the hot water tap so I am bale to cope with the low (ie: barely the Cimbali issue standard) water pressure I have at home as the boiler is
not under pressure when the D/1 is turned on every morning, so the boiler quickly tops up to where the sensor is, replacing the small amount of boiler water my milk steaming has used up.
Asides from this (IMO, the
most important issue) when the doser tank is full, the doser circuit permits a few things inside the machine to happen eg: allows the pump to work until the desired volume is reached. This means that this circuit would have to be modified.
From my point of view, if you can/are allowed to install a small water purifier in your kitchen you will probably be able to plumb in the D/1, which is I think the least expensive way to go about it.
BTW: Don't forget to make some provision (I use a bucket) for the tray below the group.
Hope I was of help.
Cheers,
CIV
