Hello:
First, thanks a lot to all of you for the input.
Much obliged. =-)
ragwo wrote:Maybe it's possible to use the same custom fitting ...
Not the same one, it's probably too long.
I am now in the process of boring through and modifying the head of a M6 SS bolt to solder a 1/8" brass tube which will in turn harbour a small NPT probe connected to a readout, all from a digital thermometer I took apart. Ken's sound observations tell me that the length (ie: exact position of the probe) has to be though over thoroughly. The hexagonal head mod is just to help it seat properly.
dsc wrote:... getting a leak proof tight connection ...
That element is round on the outside, so you would have to somehow make it flat ...
The risk of a leak can be adverted with some teflon tape or the right sealing goop (blue, not red). I have already tried it out with the bolt in place and it does not leak with a stabilised machine and brewing.
With respect to the brew-head being round ...
erics wrote:... a thermocouple to fit the La Cimbali and yes, I have NO PROBLEM shipping ...
Thanks a lot for your offer (and the compliment for BA), but these days the customs charges would make it a rather expensive proposition.
erics wrote:... that screw fortunately has a machined counterbore so no problem with sealing.
Quite so. Which is why I am having about 0.75 mm of the bottom part of the bolt's head turned so it will seat flat inside the counterbore you mention.
Ken Fox wrote:... disagree, however, with the length of the probe.
... I had considerable experience using probes located in this exact place ...
... the probe is too long if your goal is to monitor a temperature that will mean something ...
If anyone out there knows about how the Cimbali Junior behaves it's you, so I cannot but to agree. =-)
I had doubts about where the probe should go, hence the post.
Ken Fox wrote:... design of the Cimbali is such that there is tremendous influence of the group head temperature on the shot temperature, and the group head temperature is very much influenced by the ambient temperature ...
I have recently discovered this to be exactly as you say.
At this moment, I have all the panels (back, side and top) taken off for the purpose of studying how to add adequate insulation in a painless and repeatable manner. By 'painless and repeatable' I mean easy to put on (without having to take the unit apart), to take off if needed and then put back on again, with no destruction of the insulation in the process.
While attempting to ID the places where the Junior loses the most heat while idle / brewing, I discovered that the brew-head is a very important part of this process, probably more than the boiler itself. A probe lodged between the frame and the brew-head (where it is bolted to the boiler) will read a whole 7.5° C more if I cover the brew-head with some ceramic wool, with the obvious influence this has on shot temperature and boiler cycling.
Ken Fox wrote:... especially important if the ambient temperature in the room is variable.
So I have seen.
I hope to be able to control this somewhat by placing thermal insulation under the shield that covers the top and the back of the boiler, on the inside of left hand panel but only where it covers the end of the boiler and also under the warming tray, albeit only in the area where it covers the boiler and brew-head so as not to cause damage to the three-way valve's coil. I would want that this thermal insulation be a permanent part of these panels so that it comes off with then.
Ken Fox wrote:... will monitor more precisely the temperature of the flowing water ...
... problem is that by the time the water starts to exit from the group head screen ...
... experience with Eric's TC device in E61 machines cannot be directly extrapolated ...
... Cimbali grouphead, whose thermal characteristics are quite different.
Yes, I think you are quite right.
I have never seen a E61 but the photos and drawings on the web tell me that it is a much more complex design (chambers, siphons, etc.), a different animal altogether.
Ken Fox wrote:... use a probe that is much shorter, perhaps centered right over the group screen screw.
... the temperature that you get will be much more representative of the group head temperature ...
I agree.
When I first experienced the difficulties this type of machine presents the new user, the first place where I thought I could put a probe was in the small protuberance at the top of the brew-head (problem: hole needed) but then I discovered the cross section on the web, different from the one in the manual that came with my Junior and the threaded hole at the front.
After reading your posts, I am also studying the possibility of adding a PID/Pt100 combo I have to the boiler while keeping the Sirai as a back-up at 1.5 bar. I have now set up a digital timer to switch on the Junior at 05:30 so I can play with it in the morning before I go to work, but I would really like to sleep till 07:00.
My apartment is rather small and the Sirai's 'clack/clack' drives me nuts. =-/
I will post photos as I advance with this project, slowly but steadily.
Once again, thank you all for your input.
Cheers,
CIV
