Update ...
erics wrote:.... opt for a copper sealing washer (or teflon washer) where the screw meets the grouphead ...
You were right on the dot there.
It did not leak (not even a wee bit) for the longest time.
But one day, while doing a back flush I looked and noticed a very small drop of water starting to form.
Teflon used as per your suggestion and problem solved.
erics wrote:Measuring the temperature at a location closer to the point of dispersion as Ken suggested ...
Right again ...
Ken Fox wrote:.... interested to see how useful the different measurement points end up being as regards shot temperature management, which is the only thing that really matters ...
... can see a real potential benefit to the shorter probe, but not having tested it in actual use this remains merely my unproven, hopefully educated, guess.
Quite so ...
And a very well educated guess it was. =-)
Both you and Erics were right about the location of the probe being better right above the dispersion point.
Unfortunately, I am unable to find my notes with the hard data (ie: multiple scrawls on various pieces of paper while under the influence of caffeine) but what I can do is attest to the usefulness of a probe inside a well ending above the centre of the shower screen.
With the probe inside a deeper well (ie: where it intercepted the water coming from the HX) the readings fluctuated sharply, both up and down as the brew water passed through it and as a result, the temperature of the brew head itself (ie: what we really need to know) was something that could not be monitored reliably.
Now, with the probe located above the centre of the shower screen, this did not happen. Of course, the readings did fluctuate as water was pumped through the brew-head but this fluctuation was smooth and not sharp or abrupt. It is to note that it's magnitude decreased (but did not cease) till it reached a point around the value set by the pressurestat as the Cimbali's 'body temperature' stabilised.
I have the idea that the use of melamine foam (or any other thermal insulation) to cover the top of the brew head should keep heat loss to a minimum and help this process become smoother still. Some sort of heat loss protection to the boiler should also help, but there more than anything by keeping pstat cycling down, and saving energy, of course.
Cheers,
CIV
