another_jim wrote:This problem is either caused by very old coffee, a Sumatra or an improperly adjusted grinder.
This is what I assumed too. But so far as I can tell it has not turned out that way.
As for the grinder, I've always adjusted my Vario every month or so, just to be sure it is where it should be (where the burrs start to make contact when the macro arm is at zero and the micro arm is halfway up--as described in the manual, and Baratza confirmed this with me when we were on the phone). Once these problems started, I checked it over several times (including both the larger allen screw, under the rubber cover, and the smaller allen screw that is not) to be sure. There was no problem there.
As for coffee, all of it was 5-8 days from being roasted, which is what I try to do as a rule. It happened with quite a few different beans, but none was Sumatra. (One roast did have some Sulawesi in it, but it was about 20%. And other roasts had none.) Plus, the pull wasn't even close to normal. In the past, if I have pulled old coffee, it is faster, but you can just adjust finer and it will slow down considerably. For me, it is gushing even when I have the grind level almost to where the burrs are touching.
So as far as I can tell, then, the grinder and the beans are not the issue. Unless there is something further I should try to test those variables out.
