Checking an E61 Espresso Machine for Scale - Page 2
It worked well. Thanks!erics wrote:Give the flange a gentle tap over the bolt holes with a piece of wood. If that doesn't do it, give it an equally gentle tap(s) in the horizontal direction.
Christian B.
- nixter
I have had my Giotto evo for almost a year now so I think it's time to check for scale. My tap water is some of the softest around (0.3 grains per gallon) I couldn't find a lower number in North America. Even so I run all my water through a Brita. Is the condition of the mushroom enough of an indicator of scale? If my mushroom looks clean should I just leave it another year?
- erics (original poster)
- Supporter ★
I would change that one year to six months. Another thing you can do is to time the warmup to a particular grouphead temperature, say 150F (or say,60 C) under reasonably similar ambient conditions. Make a note of the times and date it.
- nixter
It took me a few tries figure out what you meant! So you're saying that scale will slow the warm up? Will it affect peak temp as read by your adapter? I've noticed that idle temp is down 2 degree F in the last few months. However that could be due to ambient temp.
- Supporter ★
Yes. Scale inherently affects the operation of all heat exchangers. Most (not necessarily espresso machines) are designed with SOME degree of scaling in mind but this varies with a whole host of other factors.So you're saying that scale will slow the warm up?
I'm having some problems after I cleaned my mushroom.
I removed the mushroom, soaked it in a citric acid solution, poured a fully dissolved citric acid solution down the valve with a blind filter on, and let it sit overnight. After replacing the o-ring and gaskets, I put the mushroom back in and turned the machine on. I'm not getting any water if I turn on the pump though. I think the citric acid may have removed too much scale/chrome flakes, and it's clogging group?
What should the next steps be? Should I try more citric acid to see if it dissolves the remaining chunks? I'd like to remove the dispersion screw, but it's stuck on pretty hard so I'm going to have to get a draglink socket.
I should note I have the E61 solenoid group, not lever group.
- Supporter ★
Order some replacement silicon o-rings for the brew solenoid. Disassemble the brew solenoid valve - the cylinder that the solenoid is on should unscrew from the housing you pictured.
- cannonfodder
FYI, citric acid will do nothing for the coffee oils in the group head. It will break down calcite but you need a detergent to clean up the old coffee oils. Something like JoeGlo works wonders for that.
