cannonfodder wrote:Go to the hardware store. Buy yourself a stubby handled wide bladed screwdriver. They are only a few dollars. Right tool for the right job.
I found that the width of the screw's slot for the E-61 (on the VBM, anyway) is long and wide. Some stubby screwdrivers generally available do not seat well in the entire slot, width or lengthwise. With the possibly limited space the user will have to hold the handle of such a screwdriver as well as the limited visibility because of the short handle combine to increase the chance of tilting the driver and having it slip out of the slot when torque is applied. The result can be a damaged screw, damaged shower screen, or barked knuckles (BTDT too many times over the decades). Some may find it possible because not everyone wears X-large gloves like I do..
Those screws can be very tight. I know mine was, and I tried various screwdrivers including a stubby as you showed, but it was not possible to safely apply enough torque while maintaining a perpendicular angle of attack. With the modified quarter held by the adjustable wrench to apply torque it was VERY easy to break the screw loose. Torque could be easily applied without straining and it was very easy to observe the placement of the quarter in the slot to be sure it stayed seated properly.
