by GriffDeLaGriff on Mon Dec 31, 2012 7:54 am
Basically, I can't seem to get more then 9.8 bar on my machine, and I will tell you why this is a problem, and perhaps someone knows whats wrong.
The story is - I had alot of channeling at home but didnt see this on other machines as much so someone said check the pressure. I dont have a pressure gauge on my machine (La Nuova Era Cuadra) so I built one.
It showed 13.5 bar so I adjusted the OPV as much as I could and it gave me about 11 bar and that was the end of adjustment so I was happy there and got pretty ok espresso. There came more water in the driptray of course, but it was ok and I just enjoyed the coffee.
After a "long" time I noticed how the driptray got almost full in a very short time so I immediately thought of the OPV. At this point I was gonna be ok with getting a little higher pressure back if it meant not so much water in the driptray. The problem was that the OPV was stuck and I tried to get it out with all my might and it broke. The key just went round and round.
So I ordered a new one (along with a new set of burrs for the M5).
I got it, installed it, and checked the pressure and it was only about 8 bar. I tried and screw it back and forth but couldnt get a high pressure like before. So I put back the old OPV (which should give me about 11bar) but it gave the same low reading. So I put the new back in and measured from the very ends of adjustment (from all the way in to all the out) in increments of 180 turns (and even 90 in the "sweet spot") and my absolutely maximum is 9.8 bar.
If it holds here for years then everything will be fine since it will give me about 9 bar with coffee, but I feel like something is odd.
So my question is: does a vibe pump have an expiration date? Have I used it up? I cant remember but I think I got it about 5 - 7 years ago.
There is no leaking.
Everything works - steam and making shots as usual.
I use the same measure gauge as I did before - without a portafilter attached. I cant get it 100% tight so there is some water sipping out while I measure - about the same as an espresso, exactly as the last high measure before all this.
The exact things I have done:
1. Changed the 3-way plastic connector to a metal one from chris coffee (because the plastic one crumbled)
2. Changed the OPV to a new one exactly the same.
3. Changed the quick fitting from the t-connector under the OPV to a new one (its a little different but I cant see how this should affect anything.
4. Cut the teflon pipe into the quick fitting maybe 1cm.
I think your first question is - how is the coffee? Well Im out of coffee and its closed for the holidays so I will get back to you about this, but still, any ideas about the pressure?
