Can someone please explain false pressure?
Postby nixter on Tue Dec 22, 2009 7:35 pm
I have a NS Oscar and I've always cracked the steam wand after warm up to relieve false pressure to the Pstat. Can someone please explain why this needs to be done? Is there really likely to be some pressure differential in the system that would throw the Pstat in any significant way??
Thanks,
n
nixter
Postby cafeIKE on Tue Dec 22, 2009 8:04 pm
The pressure in the boiler is the sum of the partial pressure of each gas. Since the boiler has air, not just water vapor, the pressure is the sum of the air and steam pressure. Releasing the air makes the pressure completely steam, raising the temperature.
Depending on the boiler, the difference can be the difference between steaming milk and merely heating it.
http://en.wikipedia.org/wiki/Boyle%27s_law
cafeIKE
Postby HB on Tue Dec 22, 2009 8:53 pm
nixter wrote:Can someone please explain why this needs to be done?
I asked the same question in What is the purpose of a vacuum breaker valve. Eric provided a helpful diagram:
Quickmill boiler as it cools down from ~252 F to ~72 F
The volume above the water level is greater after the boiler cools, producing a vacuum. Also, as Ian noted, the steam cools and condenses; once reheated, the boiler isn't completely filled with saturated steam, so the boiler temperature is lower because the vapor pressure of water vapor / air mixture is higher than pure water vapor. Jim elaborated on this point in the same thread:
another_jim wrote:"False pressure" is air pressure rather than steam pressure. Air expands and hits a level that will fool the pstat before the water even reaches boiling. A temperature PID would not be fooled and would not need a vacuum breaker (although the initial steam output would be thin). I have no clue where the air comes from if there is no vacuum breaker and the system stays sealed; but if the pressure isn't from water, it has to be from air.
Postby nixter on Wed Dec 23, 2009 2:51 pm
Ok interesting. So assuming the system stays sealed after things cool down then is there likely to be false pressure when the boiler heats back up?
nixter
Postby Stadler on Sat Dec 26, 2009 7:57 pm
Valves like the steam valve and hot water valves are not designed for negative pressure diff. This means that air will be sucked into the boiler as a result of the vacuum build up inside the boiler during cool down. The air is then vented by the vacuum breaker during heating of the boiler. The vacuum breaker will be open until the boiler pressure is slightly over 1 bar (total pressure).
Stadler
Postby nixter on Sat Dec 26, 2009 10:49 pm
The Oscar doesn't have a vacuum breaker which is why you have to relieve the pressure by cracking the steam valve.
nixter
Postby Billc on Mon Dec 28, 2009 12:54 am
One simple way I used to explain this to customers is:
Everything expands when heated. Gases expand faster than solids. In the case of a steam boiler with air and water; when heated the gas (the air) expands much faster than the solid (the water). The pressure in the boiler increases quickly due to the expanding air. The expanding air causes the pressure switch to activate, turning off the heating element. Once the air is released and is replaced by water vapor then everything returns to normal.
BillC
Billc
Return to Espresso Machines
