mitch236 wrote:I have a Linea single group. I have taken great pains to get the brew temp to 92c. When I make multiple shots, after about the third shot, I start getting great consistent shots.
That machine should have excellent temp stability after a 1-2 ounce flush.
Have you measured the temp of the first 3 shots to confirm a difference?
Let me ask this - what is your cleaning regimen like? Do you use detergent daily?
I'd suggest maybe pulling the screen and looking at the dispersion block to see if it needs cleaning.
You also might check other components in the brew path to ensure that the issue isn't caused by stale coffee oils that get washed away by the first two shots (into your cup).
