mteahan wrote:The Marzocco manual says you have to run the group after a 30 minute rest to bring it back up to temperature. Saturated groups rely upon circulating water and thermal conductivity of the group material to move heat from one place to another, like from where the temperature is measured to where it is dispensed.
Stainless steel is awful for transferring heat energy, which is why the older non welded Marzoccos were more stable than the new ones.
HX machines tend to rise in temp from non use as the thermosyphon doesn't stall. It is all about balancing temperature profile capabilities of HX designs to match usage. Home use of commercial machines requires an accommodation outside the expected duty cycle of the machine.
So I actually have an inferior machine since my grouphead is welded!! What you say makes sense. I am modifying a blind disk to simulate a shot. That way, I can run two shots with the blind disk and then run my shot. In your experience, does a properly setup PID make the Linea noticeably more temp stable? I'm torn about adding that (and possible the Piero mod as well) to improve shot to shot consistency.
