Can I use a 220V programmable thermostat as a timer for an espresso machine? - Page 2
thanks for the input....think i'll try it. No worries re neutral, my machine doesn't use/have one...pretty sure it's all european components so 240 all the way. Also if I mount the thermo/timer in the right spot set on high maybe it will provide a double fail safe for crazy overheating, which will not happen anyhow as I plan on only having it on for 2 hours a day. Once done I'll update this.....if it works it makes for a nice small inexpensive smart timer....the dedicated timers I have seen are all big and clunky and $$.
Isn't EU 230V single phase? (i.e. is it a 230V live wire with a neutral) This would be different from the North American dual 110V is 180° phases (two +/-110V live wires).zubinpatrick wrote:No worries re neutral, my machine doesn't use/have one...pretty sure it's all european components so 240 all the way.
I'm not sure what this mean for your particular setup... Having 110V where the machine expect 230V and -110V where the machine expects zero might present some risks?...
- allon
It presents a problem only if the machine is wired in an inherently unsafe fashion where it assumes that neutral = ground. Unlikely.Louis wrote: I'm not sure what this mean for your particular setup... Having 110V where the machine expect 230V and -110V where the machine expects zero might present some risks?...
LMWDP #331
All 2 wire 240 is single phase. You don't get three phase till you have 3 hots all out of phase with each other. Whether it is one hot at 220 and a neutral or two out of phase 120v lines won't matter; you will still get 220 across the two lines.
- pizzaman383
- Supporter ❤
You might check out this 220v timer:
http://www.aubetech.com/products/produi ... noLangue=2
I have the 120v version and use it for my Vibiemme.
Curtis
LMWDP #551
LMWDP #551
Intermatic and other makers have 30amp 240volt timers that will take some work to use, such as adding line cord and outlet but these are heavy duty items that will last once you get over the price and the bit of work to set them up.
http://intermatic.com/en/Products/TimeS ... aters.aspx
http://intermatic.com/Products/TimeSwit ... 40AVE.aspx
- pizzaman383
- Supporter ❤
Here is a plug-in timer from Intermatic that has a 240v model.
http://intermatic.com/Products/Timers/P ... eries.aspx
Curtis
LMWDP #551
LMWDP #551
The HB 114 has the specs and is only $15 at Amazon. I'd like to get one and see what kind of "guts" it has. The other's I recommended are quite a bit more expensive and I'd bet they would last longer but at $15 you could go through a bunch of the cheap ones to equal the cost of the heavy duty item. Personally I go for reliability and a "buy it once" kind of equipment philosophy.
Duke
Duke
