www.zokacoffee.com: you're original, drink like it - single origin & artisan coffee
Can I brew at exact temperatures with HX espresso machines? - Page 2
Postby cafeIKE on Sat Aug 28, 2010 3:46 pm
mastyl wrote:Thanks Tim - i am convinced that HX can get close enough.
Both technologies are dominant, but since the cost of a good quality HX is pretty much the same as a good quality DB, to me, it makes sense to go with the latter. I will get more precision when brewing and a more energy efficient machine. (ability to turn off one boiler).
Not necessarily. An HX has 1 larger boiler with a smaller volume to area ratio so it loses less heat.
Somewhere I calculated the energy saving of the DB steam boiler to be about 70w. I didn't measure the heat input on the smaller DB brew boiler, but the element is ON a LOT more than on the HX.
cafeIKE
Postby another_jim on Sat Aug 28, 2010 5:24 pm
Ian is right, DBs are energy inefficient in principle, since you are using an extra heater to heat the brew water, instead of using the otherwise mostly wasted heat from the steam boiler. In practice, a well insulated DB is more efficient than a poorly insulated HX, moreover, the new (very expensive) ones preheat the brew water with a steam boiler HX, and use much less power in the brew boiler.
another_jim
Previous
Return to Espresso Machines
